Pat, I just went through this project myself a couple weeks ago and thought I'd pass on a couple things I learned. NAPA could not get me the king pin kit, but dealer could. I purchased a complete kit for top and bottom at Randy's Ring and Pinion. This is one kit that was honestly complete, with new seals, bearings, spring, spring cover, grease zerks, bolts, nuts, lock washers, gaskets, loctite, etc. Their normal price was $46 for the kit and Randy's will deal too.
I have no affiliation with them, just happy with the good parts and service for a good price.
Instead of trying to get a 7/8" allen wrench, I took an old 7/8" hex lug nut (the long, closed-end type) and cut the cone end off flush. Dropped it into the king pin and used a 7/8" socket on a 3/4 drive breaker bar. With heat and a cheater pipe, I finally won.
The manual calls for 500-600 lb. ft. on the king pin!
Here's a site that has a great tech section on the Dana 60 with part numbers, drawings, tips, etc. There's also an online manual
here.
Hope this helps!
