I just had the KORE Recon kit installed, and I have an issue I’m hoping someone can help with.
The alignment is just not correct. It pulls to the left pretty good. They charged me for Alignment and then said there not much you can do with the Dodge to align them, and the Kore kit re-positions the whole axel out to much with out the use of a pitman arm. Now I will be the first to say I do not know much about the Dodge suspension; however, I just do not believe much of this story. The guy seems willing to work with me to get it aligned up the best he can. He called some shops in Utah and says he talked to Kore and such and says there are some things he can try, but he’s not sure if they will work. He asked me if I had any ideas that he could try, so I’m turning to you all for help.
I guess my question to those of you running a Kore Suspension is, did any of you have alignment issues, and if so what did you do or have done to fix it?? Or, is this something I have to learn to deal with??? I sure hope not….
