Being skeptical of a design is fine. Smart in fact. Making an assumption that a given product is possibly inferior due to the material isn't. Each material has it's own inherent drawbacks. Manufacturability, price, tensile strength, modulous of elasticity(stiffness), corrosion resistance, impact resistance, weight, fatigue strength... The list go's on. If aluminum were not a viable material, then every dirt bike out there would have rear tires laying behind the rider after every jump. Can you imagine what a swing-arm endures? Some Class 1 cars have aluminum spindles, and A-arms. Bicycle cranks have been made of aluminum, with steel pedal shafts threaded directly into them, in single shear, for a long time now. Not uncommon to see a bent pedal shaft that was sticking out of 3/4" thick aluminum crank. With complex shapes, CNC maching is easier than cool box section fabrication. CNC maching of steel, is slooowww, and hard on tools relative to aluminum.
In any given design, the pro's and con's of each type of material, manufacturability, and price have to come into play. After prototypes have been made, design validation takes many forms. Is racing a 1000 mile race meaningfull? Sure it is. So is sending parts out to testing houses and taking parts to failure. I would imagine both are pretty expensive. Every mile I drive is further validation for the strength and resilience of the KORE shock tower. Is JOblenes concerned that the bearing caps on his shocks, are bling bling red anodized aluminum? Probably not. It's a proven design, even raced in Baja a few times for design validation.
I am not here to pick on JOblenes, blind assumptions are not at all uncommon when it comes to materials in the engineering world. I was once in charge of designing a sonar system for a top secret "platform". Common term for a submarine you are not supposed to know about. The whole thing is skinned with 6Al-4v Titanium, ELI ASTM B265, Grade23. Now 6Al-4v is commonly available, albeit expensive material. The ELI bla bla bla means that it is the good stuff for thin sheet, fracture resistance(submarine hull walls). We were required to use this material on our massive block of titanium that couldn't crack if it were dropped off the Empire State Building. A case where fracture resistance was not an issue, the standard material would suffice. Thin skins of aluminum with rivet holes all throughout them(like a wing), are good candidates for stress fractures. Big chunks of 7075-T6 for control arms really aren't. I trust that the engineering behind them was performed in a professional manner. Until I hear of failures in the field, I will not be concerned by any engineer, designer, fabricator, or other random critic's claims of inferiority. The aluminum control arms fit a need, and they seem to perform their job. Yes they could be made of steel, titanium, maybe even nodular iron... But they are not. We all have options, if you don't like what you see, don't buy it. But don't doubt the engineering behind any product because of any one man's rantings. There is more than one way to skin a cat... .....
