Yes, I used the search, and can't find specifics on the following.
#1 The coils aren't marked, how do I know which side is driver & which is passenger?
#2 Does anyone have pics of the rear mini-leaf pack on the truck and how it goes exactly?
#3 Where do you mount the Fox shocks resevoir? I've seen pics, but what are they attaching it to exactly (front & rear)?
So if I'm correct is this the basic jist of it:
Jack up axle
Support frame on jackstands
Lower axle but still support the weight some
Take off the wheels
Unbolt the shock mounts, steering parts, etc that is specified,
Remove the stock coil
Put in the Kore coil
Bolt in the Fox shocks, mount the resevoir
Bolt in the 2 drop blocks
Put in the bumpstops
Tighten up everything
Jack up the axle
Remove jack stands
Lower axle
Front is done?
Jack up the rear axle
Unbolt the leaf back u-bolts & top of leaf spring thingies
Remove the stock overload sprint or whatever
Replace with Kore minileaf pack
Put Kore U-bolts and put everything back together (without stock overload spring thing)
Bolt in Fox shocks, mount resevoir
Tighten everything up
Jack up axle
Remove jack stands
Lower axle
Rear is done?
Go get alignment
Drive around and enjoy
Is this right or am I a moron?
Jack up axle
Take off the wheels
Jack up the axle
Remove jack stands
Lower axle
Front is done?
Jack up axle
Remove jack stands
Lower axle
Rear is done?
Go get alignment
