Kore Stabilizer Bar Drop Block Install... article/pics
Had a little surprise on the way home tonight...
Anyone running 37" MTR's with NO lift??
I have had no problems with my lift in general. It's mild enough to not have a drastic effect on the front pinion angle and if it does, I think you have other issues. I ran mine all winter with 4x4 on many occasions. I drive all the time every day, the front shaft has been fine. Remember, it's always connected and spinning. There is no axle disconnect. I also run a heavy plow.
Raising the front a couple inches is well within the stock travel of stock suspension geometry. In otherwords you are still within stock driveline angles of all components except not in the middle of it. That's why it sometimes takes some minor tweeking like these drop blocks to perfect the system.
Tires are also a biggy. Some can be troublesome. "E" rated is the best way to go.
I have been running a lift for 2 years and zero problems, (almost) the rear driveline angle had to be adjusted, and it agravated a defective front drive shaft and created Death Wobble, which I fixed with allignment and MTR tires... . other than these "minor" things NO PROBLEM... . but now I got it wired, and Yo Hoot your are 100% correct on the tires... that's a BIG deal... go with E rated.
