Kore steering retrofit
Voltage Surge
york compressor question
Has anyone used the Kore MFG. Mopar factory steering Retrofit kit for upgrading steering problems. This is a 08'-11' kit this is pt# 1A5006 w / 1A5002 stabilizer any feedback would help with my purchase... . It's not cheap.
It looks like the same kit that you can get from Dodge only that they replace the factory steering damper with their own. The Dodge kit is a good kit, I'm very pleased how it has held up over the past 90,000 miles I have had it in my 05 truck.
Thank u for the advise I think it's going to be fine. I think anything other ther what's there now is an improvement . Thanks again.
:-laf:-laf Now Kent is claiming a Dodge part is his own... ... ... ... .....
what is wrong with the steering????how does this upgrade the truck... thanks
Upgrade is to meet 08-11' steering components. bigger tie rods and thicker pit arm. Better steering stabilizer (bilstein). I just received it I'm having it replaced on Monday. My issue is wandering steering and knocking felt in steering wheel and floor board. Tie rods showed wear 70,000mi.
It will not fix what you are feeling in the steering wheel and floor
Just had new kit installed seems a bit better haven't felt knocking but before it didn't happen all the time. Is it somthing else and will the knocking return. One thing it has always drifted to the right on all grades on the road. Alining won't correct problem... . My main concern is that I know my steering components are up graded and reliable.
