KSB plug, leak repair
For you all out there that do this on a regular basis this leak fix is a piece of cake. I am not a diesel mechanic nor do I have automotive maintainence training, I just need my truck to run reliably. That being said; I remember about cleanliness first, on injection pump systems. I flushed off the outside and wiped down the work area with a lint free cloth. Removed the plug. No fuel leaked out. Part number 3 and 4 in the exploded view were the subjects for replacement. Inspected #3 o-ring that was captured on the plug shank. Measured it with a vernier caliper to match it to a new o-ring in the DGK-121 kit. The #4 o-ring stayed in its seat in the pressure control module bore. Stripped a piece of copper electrical wire and used a dental mirror and removed the stuck o-ring. The #3 o-ring was cracked and flattened and very brittle and the #4 o-ring was severely flattened. Located o-rings in the kit that were oversized in OD and undersized in ID by a slight amount. Soaked everything with MMO and assembled the o-rings to the plug. Screwed the plug back into the housing until it got tight. It was still quite a ways from being in position but the #3 o-ring had not seated as yet. When that slipped into its seat the plug got loose again. I tightened it until it seated with a pressue measured in 'THUMB POUNDS":-laf. Anyway, IT DONT LEAK NO MO' I hope this helps others out there with the same problem. BTW the plug appears to have a ball and spring check or relief valve in it. I dont know if there are parts or a replacement available for this. GregH
