Hi Bill,
Welcome to the TDR and the 1st Gen group... . good to have ya. .
In regards to your question we could use a bit more info...
>Is the truck hard to start when hot/cold?
>Does the truck idle differently when hot/cold?
>Are there ANY other symptoms that seemed to coincide with this problem. . did your mileage change?
>Did you do any work or adjustments to the truck just before this happened?
>Are you having cold weather?
>>anything else you can think of to toss in here will help...
At this point I don't think it's your KSB solenoid. On your model year the type of KSB you have is called a "wax motor" KSB. It is triggered by a sensor on the intake manifold and fed approx. 10 vdc until the sensor detects intake air temps warm enough to no longer require the KSB's function.
A louder engine sound can be any number of things... for example you may have developed a bad injector or two... that can happen and they sound "knocky" when this occurs.
You may have some lifters out of adjustment but that would not be an "overnight" change but rather a slow increase in metalic sound as they loosen due to wear, or ??
One other item which may be a possibility is the flexplate. The auto has a flexplate that attaches the torque convertor to the flywheel.
When they start to fail (as in my case) they start to sound a bit like a rock in a tire "ticking", then slowly they develope further until it sounds like a bit of "timing knock"... after that it's not long before you're stuck on the side of the road.
Try to post a bit more info and we'll all try to help you out on this one... .
pastor bob...
