Competition ladder bars
Competition Driveshaft loops
Competition Sonora Pull
I'm going to be fabbing up a set of ladder bars this weekend and was just curious on how long most people make them, how far up the frame they put them, and what length seems to work the best. Is it the longer the better. There going on 12v, ext. cab long bed with 4. 5'' skyjacker stage II kit.
Travis
8' long---no more than 3" below axle and at the frame I mounted mine underneath about the same 3" distance---DOM tubing---NO PIPE----chris
are you using heims or just drilling a hole thru the tube and shoving a bolt thru---if you're using heims I think 1 3/8" is to small as you'd need a small heim---but if you're going hillbilly with the bolt shoved thru you'd probably be ok--the wall thickness is good--mine are 1. 75 x. 25 with 3/4" heims---chris
Travis. .
I have some underside shots of the ones on mine in my readers rigs area. If you need them a little larger drop me a PM with your email addy and I'll pull them down and send them as they came out of the camera. I will be around the house all weekend long with nothing much to do so if you want to look them over let me know and I'll slip out your way and drop them for you to have a look at in person... ..... Andy
