Hold on a minute. I'm at work right now (and can't access my Owners Manual to double check the following) however, as I remember reading, any tampering with the speedometer or systems affecting its accuracy is grounds for warranty denial. Think about it... adding larger tires say, like my 285s... increases the circumference of the tire about 7-8% (if memory serves). That would be the same as giving yourself a warranty extension of 7-8k miles over the life of the 100k engine warranty (assuming no speedometer correction). After reading it I said Ha! I did correct the spoeedometer with an Abbott E. R. A. Heck, I even had Abbott work up a special correction ratio for me that proved to be exactly right on (when the tires were brand new). After further thought on the subject, it appeared that DC could void my warranty (or parts thereof) because I added the correction device, thereby altering a speedometer parameter (I suppose this could be loosely construed as tampering)... even though I corrected an inaccuracy. Heck, it's more accurate now than when it was delivered to me by CC (pre DC).
Hey Tom, just purchase a VA CPC or one of the new Edge EZs to compensate for the tire change and resultant loss of power. Just a thought.
Warranty? What warranty?
..... I think my Infinity sound system is still under the extended warranty. . that is unless all the Dynamat I added voided it somehow.
Keep in mind that I'm not even sure what I read in the Owners Manual could stand up in court against the Magnuson/Moss Act* if persued by DC however, they have much deeper pockets than any of us.
(* that's Massey/Ferguson Act for you Tom).
I just thought I would add this into the mix... either way, it wouldn't have changed my decision to add the larger tires and Abbott E. R. A.
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Amsoil Dual Remote Bypass, Optima Yellow Tops, Bosch 275s, VA CPC, (censored), Aeroquip braided s/s fuel lines, Banks 14 cm2 turbine housing/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
