"Lamp out" dinger on LED flatbed lights driving me nuts....
Rebates Extended, not changed.
Need some measurements! quick!
geusterman
Those of you that have changed tail lights... mine a flatbed with LED lights... can cause the puter to throw the "lamp out" warning and I don't see it in the puter to remove. Any suggestions? George
What is the wattage of the stock bulb? The problem is that the LED draws much less current than a stock bulb, so the computer thinks the bulb has an open filament. One fix is to solder a resistor in parallel with the LED to bring the current draw back up to something approaching stock levels. If we know the wattage of a stock bulb and the current draw or the resistance of the LED, then we can calculate the required total circuit resistance of the LED/resistor package and the size and wattage of the resistor that you would need to add.
Rusty
thank you fine TDR gentlemen. could not ask for more. well,... anybody live near Mount Vernon WA?... . Nevermind! Thanks again. George
