Or perhaps the real blame lies with Dodge?
I attempted to install a set of Lance cabover strut mounts tonight on the truck. After drilling and tapping the holes, I naturally went to mount the brackets.
Wasn't I surprised after just getting the 5/16" mounting bolts snug THEY STRIPPED OUT!!!! I couldn't believe it. It wasn't like I was using a great big honking 1/2" breaker bar to tighten them. Just a little 3/8" ratchet.
Am I ever ******. 4 now useless holes in the truck. Actually only two are stripped out. One on each side. I don't think I want to run 'em with only one bolt anyways. I'd probably strip them out too when I got them tightened to a massive 20 ft lbs or whatever I got the others to.
Maybe I can salvage it with some helicoil but there ain't much to get ahold of on that thin sheet metal I guess.
Maybe I should drill the holes a tad larger and tap for a 3/8" bolt then tighten the bolts with a wet noodle.
I wondering even if I do mount the brackets how long they'll hold up given the "strength" of the metal they're bolted to. Jeez!
Dang it anyway!
Tim
Dang it anyway!
Tim
