If you wish to do all the seal replacement yourself..... i can get you the o-rings... but i ask you contact a FASS dealer to get this taken care of as we dont sell retail.
AS for your leaking shaft seal, go to NAPA and request the following Part numbers:
CR-3101 (Buna... . go with this one if all you run is diesel..... WAY easier to find. )
CR-3103 (Viton)
Motor to base bolts 75 in/lbs.
NOTE: I only suggest this for someone that understands their pump is totally out of wnty from our stand point. Any pump that is still under wnty, we like to do the seal change. Your pump didn't have a wire seal due to age... but to anyone else reading this, if you have the wire seal, and its cut... you just took your wnty into your own hands... ... OK... PSA done!
