Hello All!
I have removed the transmission & transfer case as one unit.
It worked nice, jack placement is important.
I have a SMALL leak on the rear seal and everyone says replace it!
I called Cummins Atlantic and the service guy said the speedy sleeve is not used any more.
My question is:
How do you remove the seal? I have seen a puller made by K-D.
What type of a press is need to install this seal?
Does anyone have the part number for the seal? If the is a groove cut the shaft apparently Cummins has an over-sized seal instead of the Speedy sleeve.
Thanks,
Tom
My question is:
Thanks,
Tom
