leaking valve cover
Box for early 04?
Weekend experiment w/the SRT 10 Hood
I was just curious if any body has had a valve cover leaking. I was taking an oil sample today and noticed oil on the intake manifold. :( I noticed it was wet right at the gasket all the way around.
There was another post about this a couple of weeks back. The solution (that worked) was to torque down the valve cover.
Yep, I started that post. I was told by those that also have this problem that it's normal, but not everyone has this problem. :confused: I personally think it's crap that a new engine has a leak or "seepage" as some prefer to sugar coat it , but very few others shared that feeling.
What year is your truck? My upper and lower gaskets were replaced a year ago because of "seepage". They are now leaking again. I would also like to try and re-torque the bolts.
A better method would be to remove the valve cover and tighten the girdle bolts, then do the valve cover. That will get everything.
Vaughn
My 03 leaked a bit when new. The valve cover seal was twisted in the grove. Took about 20 minutes to pull it and straighten out the seal. Never leaked after that. Like Vaughn said, while your there, tighten the rocker box bolts.
In fact, while you have the cover off, fire it up if you want. They do not make a mess at all. If you see how much oil there is up there, you will see why they last so long.
It seems like we shouldn't have to do anything to these engines, BUT as they break in, they need to be gone over with a torque wrench. Several heat cycles tend to make everything seat. On the three that I've owned, the intake system (clamps and intake cover) bolts needed to be torqued after about 10 K. Usually at 10K, I'll just go over the entire truck and torque everything.
