Leaky 4X4
MPG with my 1999
Removing 'A' pillar trim
I have seen a previous post on the breather leaking on the front axle but that was when it was filled.
My last oil change (2,000 miles ago) I checked the axle oil and it was fine. Thursday I saw a little puttle under my ram and thought the turbo return line started leaking but when I got under it I saw it was the 4X4 breater puking all over. I let it go thinking I might have had the front end tilted twards the passanger side Wed. night. Today I looked under the ram and still saw a wet spot on the drive and am starting to get conserned.
Question is should I be or what else could have caused the problem.
Thank you in advance.
Mac
95 Ram 2500 Auto Std Cab, Cat & Muffler Fell off, 125,000 miles.
Bombed-to-be!
Mac- My 99 puked 3 different times over an 18 month period and when I checked the fluid level it appeared withing spec. Mine never left a puddle so you might want to plug the plug and see how much fluid is left before getting concerned.
On post suggested that the clip that holds the tubing to the frame was pinching it shut which doesn't allow it to vent properly.
4-sale or Trade
'99, 3/4, QC, SLT, 4x4, ISB, 5sp, 3. 5xlsd, tow pac, HD tcase, tow mirrors, camper pac, White over driftwood, Mist gray interior. With less than 19,500 miles.
I took the tube out of the clip by the top of the shock, cut it, inserted copper tube/clamps, reinstalled, quit puking.
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps-Tuff Country control arms-2" coil spacers
Check vents closely. My t case also was plumbed up to right front fender. Thwe breather tube was not opening and puked allover fender. Also the rear t case seal was leaking fluid because it could not breath and the fluid was being forced out the seal.
