I think this is the problem I am having. Being a gas mechanic, that is the best way to describe what is happening. With my recent install of new turbo, I now have a popping noise from the intake under heavy load and throttle. If I keep the boost below 30 psi, the problem isn't there. I can make it happen even empty in 5th over around 75 if I really push it.
I'm thinking with all the air I now have, I may need to adjust and get a little more fuel. I really think I have a lean fuel mix under extreme conditions.
When I did the 3k and lever adjustment earlier, I had to go back and move my #11 plate back to stock position to cut back on some of the power.
What do you diesel gurus think about pushing the plate . 030? That is where it was before I slid it back.
What will i get in egt's with the extra fuel? I'm thinking if I don't have the lean condition, the temp's may not be as much a problem.
I can control this with the right foot, but now cannot use full throttle, which is a real bummer.
OPEN FOR SOME EXPERIENCED INFO!!!!!!!!!!!!!!!!!!!!!
