Let the BOMBing start
Clutch pedal travel
DD True Torque jumper settings
Well I picked up another 1st gen with a 215 hp & nv4500 combo. Running powerpack <banks> all stock motor pulling 24lbs of boost. Milage is around 17-19 hwy. Approx 70,000 on recon motor. Where is a good starting point. Dyno showed 178hp to rear wheels last week. TIA, Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, CTD 3500, Air brakes on truck & trailer. 193,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy. 200,000 miles
Just bought another 92 D-350 215 P-Pump motor and NV 4500 180,000 miles 24 lbs boost all stock For now
I would start w/ a TST torque plate, AFC spring kit. Either the #12 (230HP/605T) or the #11 (280HP/685T). I started with the #12 plate and then the bug catch me by surprise and then the #11, then injectors & turbo housing and I'm not done yet. Who knows where this will all end... .....
Have fun #ad
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
[This message has been edited by drawson (edited 03-30-2001). ]
Thanks for the input. Yea got the BOMBing bug for sure Thanks again, Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, CTD 3500, Air brakes on truck & trailer. 202,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy. 211,000 miles
Hi Drawson, why did you recoment the spring kit with the 230/005 tst kit? I have the 230/605 installed and I was told by Mark at TST that they do not recomend it for this uprate kit only the higer HP ones.
Just Curious
1995 green 2500 3:54 K&N air filter, TST, EGT and Boost gauges, Amsoil synthetic oil in rear end
TST 230/605 power uprate kit. Bed liner, Reese 15K 5th wheel hitch, New name will be Plenty of power for me :)
The AFC spring kit is recommended with all 215 hp engine uprates.
Raising pump timing to 15-15. 5 will usually improve economy up to 2 mpg.
The 280 hp #11 plate takes the egt and torque to the max the stock turbine housing and clutch can take. If you want that much power, start saving for the 16 cm2 housing and a better clutch--sooner or later you will want them.
I prefer to stay very conservative #ad
609 hp is almost enough.
Oh come on Joe, Last year 510 was almost enough now it's 609 what is next 708? As far as the AFC spring kit goes. It makes it so that I can get the smoke pre-boost down to just a puff and still be responsive. To get it to be that responsive with the stock spring there was alot of smoke pre-boost.
I gotta agree with nopowerforme, I talked to Mark at TST also, and he did not recommend the spring kit for applications under 300 hp. Why the conflicting info?
'96 4x4 Auto, Ext Cab, Long Box, Kitty Be Gone, TST #6 Plate, AutoMeter Pyro and Boost Gauges, Jannetty rebuilt transmission with Pro-Torq Convertor
Not really a conflict. If you have a 160, 175, or 180 hp pump, the spring kit is recommended for the high hp torque plates mostly (OK with all but not needed as much with #8,6 plates), that is, get the AFC kit if you have #5 or #4. With the 215 hp pump, tuning for minimal smoke with good response is easier with the AFC spring kit with any of the plates, #12, 11, or 10.
