Matt,
Here is a little info on the lights. I use the HID
Baja Designs Soltek Single HID & Halogen Light
Finally, a lightweight (under 5 lbs!), integrated ballast, pedestal mount, 8” HID Light. Baja Designs – the leader in off-road motorcycle race lighting – brings more than 10 years of experience to the 4 wheel market. Not only are they racers themselves, but they support racers such as Johnny Campbell, Larry Roeseler, Ty Davis and numerous other Baja 1000 and Dakar racers.
Located at the top of the Soltek light is the Baja Designs patented, billet aluminum, Quick Adjust System. This allows for on the fly, up-down adjustment of the light – no tools required. Of course, each light also adjusts side to side. The light mounts easily to your existing bumper or roll cage using either a one or two hole mounting configuration located at the bottom of the chromoly frame. (The two hole configuration prevents the light from vibrating out of adjustment while driving). Since you don’t have to worry about an external ballast, mounting these lights is quick and painless.
This light weighs in at a slim 4 lbs 10 oz! Yes, that includes everything. The light is available in driving or pencil beam. It features a Tig-welded 4130 Chromoly frame, rubber vibration isolators, billet aluminum light ring, integrated HID ballast, all stainless steel fasteners, high quality Baja Designs glass optics and is double O-Ring sealed. HID components are neatly confined within a High-Impact glass reinforced UV nylon housing.
