so i will try getting to the tone ring mod tomorrow... 1/8th inch if not less should all i need to remove from the hole to get the right amount of advance. from what i read 2 degrees is about the goal.
HOW can i check this? i know my timing light wont work on a diesel... or will it?
can i clip the lead to the #1 fuel injector lead to know when it is sending fuel? i know this would be a way more broad deal than a spark plug that only fires once. if this would get the strobe to fire what to i index the timing off of?
i know IF it were to work i cant make adjustments without shuting the truck down and rotating the tone ring again... but atleast i have an idea of how many degrees i have changed everything... .
ANY input is more then welcome.
thanks
Grant
thanks
Grant
