Level the truck
GREEN High Performance Air Filter
Changes for 2005??
I am wondering if I could lower the back of my 4x4 and still have all the Anti lock brake system work. Will there be any other issues to consider. I need to lower the back so I can get the 5th wheel closer to level.
I'm not sure about the brake system when lowered. I ran into the same problem with mine as far as having the 5er level. I ended up lowering the body of the hitch about 3 inches, worked out great with plenty of clearance for the bed. This is just a thought in case you have not tried this first.
Bert
Level 5th wheel
We had to have the 5th wheel raised. Open Road makes I-beam attachment the gives 8 inches clearance. Dodge had heart attack when I asked them to change truck level as they said drive lines would be strained.
Other RVer's having same problem.
Thanks for all the help. When I lowered my 1998, I used a 2 inch lower block. After I did that I had to cut down the shaft that hooked to the axle and the rear proportioning valve. When I did not cut the shaft down the brakes would work like I had a big load on the truck.
