Well I did it!
When hauling my trailer with the 19. 5" Ricksons, the trailer was up in the nose about 1"... as told on the level indicator... Hitch on bed and on trailer was all the way lowered so no more adjustment there...
Figured I needed some more room on the bed-rails anyway as I have a toyhauler and staging areas are not always flat. . Found out the axles were straight and UNDER the springs already!..... So I was to raise the trailer 2" and then raise the hitch adjustment up 1 hole which is 1". . This ought to level it and give a little more room.
I bought some Steel blocks I had made to length and width, (2x2x4") Drilled a hole for the spring pack bolt, Bought longer U-bolts 2" longer, Started last night and finished today. Trailer is def. Up but not comical like you see on the road these days...
Hooked the truck to the trailer and put the weight on it... PERFECTLY LEVEL. . I mean not even a hair off!!... So now all the tires are getting equal weight, and there is 8" of clearance between the bed and the trailer... Much better!
The one and only bad thing about this is the height of the trailer at the A/C units... yes (2) of them. . on the front, it is up a bit for the bedroom and now the trailer sits at 13' 6" clearing at the front and 13' 2" clear at the middle. The front of the trailer slopes down to 11' 6" at the front cap... .
here is a pic of my trailer and truck from awhile back. . Will get better side pics of this later this month when I take a trip.
Eric
Eric
