Lift Kits
over head console to computer?
disconnect batteries for quick tune up
Which Lift Kits do you'll prefer. I only know of Skyjacker and one other I can't remember the name? Do you prefer the 2. 5 or 4 in. ? I don't pull much it would mainly for looks. Any help would be appreciated.
'01. 5 ETH, DEE, 2500 Silver, QC, 4x4, SB. 3. 54 LS All options except leather. Not bombed Yet. Life Member NRA & NAHC. Ron Osborne
Serious lift Procomp. Leveling kit... . tough country.
My z-71 I installed pro comp's six inch kit with tri shcok front end and beat the daylights out of her beach racing a few years back. Not one component failure. On the other hand a buddy's dodge unfortunatly broke a lower control arm off its purch (I think due to stress from the longer replacement but who knows) And that day ..... I wanted a dodge.
Y2K+1 <font color=white>3500 4X4 Quad Cab</font> Powerpacked , Jakit's Front End Leveling Kit with 255/85R16 BFG M/T's Custom Rhino Liner (as seen on website under tool man's truck feature) DeeZee Goodies, Hadley air systems 150 psi comp and air storage.
Keeping the rubber side down 'n' shiny side up Will Bring a smile at the end of each day (hopefully)
[This message has been edited by ToolManTimTaylor1 (edited 03-16-2001). ]
You only know of Skyjacker for a reason, there reputation and quality.
Skyjacker all the way
1997 Dodge Ram 2500 HD / Club Cab, Cummins Turbo Diesel (silencer ring removed), 4. 5" Skyjacker Double Flex suspension lift, 36x14. 5"x16. 5" Ground Hawg radial tires on 16. 5x9. 75 Weld Super Singles, dual steering stabilizer, 4. 10 precision gears, 33-tooth Speedo gear, Psycotty Air Induction, Mag-Hytec rear, Rhino liner, Grizzly double bent nerf bars, Bushwhacker flares, Kanduco grill insert, Confer super skid axle truss, DT Trac-bar, Moog tie rod system, Fabritech Traction bars, Energy sway bar bushings and end links. Truck Pic's
I've had the Tough Country 3" and now have 4. 5" using mostly Skyjacker parts on my Dodge. Both are quality pieces. Skyjacker springs (coil and leaf) are topnotch. If you want to go tall though, the Dick Cepek 6" series III kit has just been re-released. Very nice kit, 47" long control arms. I will be upgrading to one of these kits or using the Fabtech control arms on my truck soon. Not much difference between leveling kits but when you move up in height, the kits differ alot more. Just the opinion of a lifted trucks nut.
98. 5 Q-Cab/SB/4X4,Auto,4. 10,4. 5"lift,36/14. 50/16,VA,Stans 4" exh. ,RE0880,Ring AWOL,VDO boost/pyro/trans. temp. DTT VB/TC
