I just drove 900 miles this weekend - SF-LA roundtrip - with Briar Hopper's fuel pressure gauge taped to my windshield. I was reading the pressure at the inlet to the VP44 (post fuel filter). Fuel filter is new.
At 2000 RPM/65mph cruise I get 7psi fuel pressure
At 2500 RPM/80mph cruise I get 5psi fuel pressure
At idle/no load I get 10psi fuel pressure
Pre-fuel filter I get 11-12psi fuel pressure so it looks like it meets the manuals 10psi requirement - barely.
Here's my problem: A couple of times in the last two weeks my accelerator has gone dead - happens in 5th or 6th gear. RPM will slowly increase if I'm on level ground but it feels like there is no boost happening. I tried stomping the throtttle several times and that didn't do anything. The only code I get is P 1693. I have disconnected my VA CPC and the same problem/symptoms occur. Am I experiencing a lift pump death rattle or is it a TPS/APPS issue? Truck just turned 60K so it's under warranty but getting to the dealer is a PITA at this time so I'd like to 'help' him trouble shoot the problem.
Thanks in advance,
Brian
Thanks in advance,
Brian
