A couple of weeks ago I changed my fuel filter and after trying to start (bump the pump) the engine would not start.
I then realized that I did not hear the lift pump anymore. Thanks to a sugestion from another TDR member in the 911 forum, I pulled the plug on the lift pump and plugged it back in. I was then able to start the engine.
I just checked a few minutes ago to see if I could hear the lift pump when I switched the ignition to run (not start). I did not hear anything. Does this mean the lift pump is dead and the only reason I can start the truck is existing pressure in the lines?
know everyone will say check the fuel pressure, but I don’t have any gauges or any other way to check the pressure. That’s part of this thread.
1) How can I tell if my fuel pump is dead?
2) If the pump is dead, how do I approach the dealer and what do I tell him? I have almost 92,000 miles on the truck in 3. 75 years. The dealer I bought the truck from is 200 miles south of where I live.
3) What is a good fuel gauge? (I have AutoMeter UltraLites for boost and EGT)
4) How difficult is the lift pump installation for someone who is not all that mechanically inclined? (I believe the cost is about $150 from Cummins. )
5) What is normal pressure at idle to WOT and everything in between?
6) ... and anything else you can think to tell me.
I appreciate all your help. This is the first (potentially) major issue I have had with my truck and I want to do the truck right. Thanks in advance for all the good advice I am about to receive!
