Lift pump mounted by fuel tank, what about freezing weather?
To boost or not to boost, that is the ?
Better Fuel Filter?
I've been trying to keep up with all that has been posted about moving your lift pump back next to the fuel tank. One thing that has not had a lot of discussion is, "What about freezing weather?
If I were to mount the Mallory lift pump I just ordered back by the fuel tank, would it increase the chances of the fuel to gel or freeze-up?
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, BD 2LO kit, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HX-40 Turbo, HOT Power Edge, PE EZ, Bully Dog Stage III injectors, South Bend Ceramic Puck Clutch, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), Bar II Brush Guard with KC Daylighters and Fog lights, Ultra-lite guages with blue bulbs. </font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455&f=0" TARGET=_blank><font color=red>New Pictures of my "White Obsession" and Dyno Run</A></font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423" TARGET=_blank><font color=green>BD Dyno Days 10/28/00</A></font>
<font color=purple>
NRA Life Member! (Need to protect our rights and FREEDOM!!)<font size=-2>
[This message has been edited by BIG BOB (edited 06-01-2001). ]
Bob,
I've wondered the same thing. I was thinking that surley some makes an in-line heater that we could tie into the filters preheater with a relay. Put it back at the tank, and away you go... ... I'll have to do some research on this.
2001. 5 RAM 4x4 3500HD Quad cab. 3. 55 LSD 5 spd.
HX-40 16cm, Bully Dog 4" exhaust,Step 4 Injectors, Modidied ECM, Blue Chip Box, Propane. Otherwise completely stock.
Advanced Diesel Technology
And in case it isn't, Racor makes different filters with fuel heaters built-in. That's the way I'd go, if I were going to drive my truck in the winter. I got my brochure from UAP/NAPA (Racor brochure No. 7529), but I haven't checked prices yet.
Yes, Racor also makes an electric 300-watt in-line heater, part number 14278. Draws 21. 4 Amps. Their 500-watter is p/n 14257, and draws 35. 7 Amps.
Racor's USA phone number is 1-800-272-7537.
Tom
Tom Glover - VE7DQ, C-GWTG
99 QC SLT, LWB 4x2, ETC/DGP, Wht/Agate, etc.
I had no problems with mine, installed in late January and we had a fairly cold winter, many nights in the single digits. I'm sure not as cold as some of you guy's see, but I agree with Chris. I think you'll probably be fine with the winterized diesel, add some type of enhancer (your choice) for good measure. I ran with and am still using Stanadyne PF at every fill up. Worked for me.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
[This message has been edited by Bigsaint (edited 06-01-2001). ]
The Racor filters all have a flow rate on them, any where from 15 GPH to 120GPH. The 120GPH are very large, somewhere around 12" in height. That is too tall. They also have a 90GPH that is around 10" which might work. I will have to measure.
The thing I am concerned about is that the Mallory will pump 140GPH with a filter that only allows 90GPH through it have a negative effect on the Mallory?
In my opinion, no. While the Mallory has the ability to flow 140 GPH, you will never be close to that and I think a filter rated at 90 GPH should be more than adequate. Chris S. , I would be real interested in your opinion on this topic.
Scott W.
Bob--as I posted in the other thread of yours--the 90gph filter I'm using is doing great-I don't think there will be a problem using one of these--in all honesty we wanted to run it for a while to test it out, but since it's come up I felt it would be nice to let ya know---like said before it has a heater and WIF sensor--I've yet to get the wiring for the wif(on order) but the heater wire I just spliced into the OEM wire---chris
