biggy238 said:I'll take that as being meant in a constructive manner.![]()
Ah yes, I thought I was quite aware the it was 90*- obviously. :-laf
How restrictive it would be in it's natural state on the other hand, I needed some insight toward.
What I was getting at is the 90 is a molded bend and is not just a hose folded to make the turn. The space is too tight to take a straight hose and make it work without affecting the flow, as I tried this first before spending the few bucks on the new part from Cummins. You could possibly make a stright hose work smoothly by severly trimming the barbed fittings on both the LP and fuel heater but then I think you might be opening up a potential arear for leaks by doing so.
What could have happened is that if your LP was replaced some of the fittings on the newer LPs are longer than the original and this could cause your bend to not be as smooth. In order to make a smoother transition I had to trim one barb off the LP fitting.
Also the new hose was longer on one side than the original. I also trimmed a little off the hose to make it smoother.
If I would have installed the hose and the new LP fittings in their original state the hose would still have kinked in the middle despite it being a premolded 90.
