Following the advice posted on the forums by those of you with greater experience with CTD I installed a fuel pressure gauge shortly after purchasing my 01. 5. I've noticed over the past few weeks lower pressures at idle (12-12. 5 vs. 14-14. 5) and at speed (10. 5-11 vs. 12-12. 5) so I'm considering just going ahead and replacing it prior to potentail failure. (It will easily pull down into the single digits if I put my foot in it).
Are there any suggestions/ precautions before or after the lift pump install I should be aware of? Thanks
