RADdodge
Bob -
The sending unit on the top is actually a pressure switch that switches on when the suction between the fuel pump (either fuel pump, if the check valve is allowing the fuel to bypass the pusher pump) and the filter indicates that the filter is becoming restricted, i. e. needs replacement. That sensor along with the WIF sensor (Water In Fuel) is wired to a Racor gauge that visually and audibly, warns the driver of either condition.
