Well I went and did my semi annual fuel filter change today, took only about 15 min to change the filter and three hours to get the engine started again!!! after changing the filter I loosend the plug on top of the filter, engaged the start briefly 3 times until I got fuel cominf out (this is the one on the filtered side, toward the engine), and went ahead and cranked her, it started immediately and ran great for about 20 seconds! It died and I could not seem to get her started again. I used the "tricks" I used before, loosening one or 2 injector lines and crank until I got fuel following, ( this always worked in the past, last time about 6 months ago it took about 30 mins to get things going), this time I had 4 injector lines loose and all I could manage was a slight trickel which did not get it going. I finally rigged up a nausal with a funnel and some rags, I stuck that in my filler pump, hit the started to get the pump going then pushed in compressed air into the tank 3 times doing that and she finnaly cranked ran real bad for a couple of min and then smoothed out, batteries nearly dead, I had to jump it with my other vehicle!!!
Needless to say I think the lift pump is about pooped out. I don't want to thru the hassel of taking it to a dealer who will probably keep it for a couple of days and then give me heart ache over not being covered under warrenty, (she has 38K on it). I think I read some time back some of you replaced the factory unit with an after market pump. PLease I need part numbers and where it can be purchased PLEASE. Also, what if any mods were required to hook it up. I also remember one guy who rigged up a "helper" pump closer to the tank. I am inclined to do both at this point. I still have the stock tank, however if I can find a good supplier I will change out to a larger one in the near future, (had real bad situation with aero).
I am awaiting your prompt and honest replies! Thanks in advance!
