Lift Pump Question
Stock AFC spring and top end??
Thermostat X-pert
Installed Autometer fuel pressure gauge today 9psi idle 3psi under load not good, original lift pump 77,000 miles cant complain is there update lift pump available if so anyone know part#
Just take it to the dealer, your covered under the 5 year 100K warranty. The pump has been revised several times the latest ends in AA suffix. Good luck
Well dealer is definately out with comp hooked to pump wire i will buy it and install i got 2 numbers which one is latest for my 99. THANKS AGAIN
Just had mine replaced by the dealer, last week. The number I gave you was the latest version off this site, and the part number on my repair sheet from the dealer... ;)
Thanks RJOL ill try to track one down in AM
Forgot to mention... If your buying the lift pump, and installing it yourself, get it from a Cummins repair facility. Cost about $140-150. It's the same pump as the dealer has, but they will charge you almost double that amout for it... ;)
Checked Cummins by me early last week (just in case dealer was going to be a butt head) they had 4 coming in, $168. 00. Get info off your engine data plate before you call they need serial number 8 numbers all numbers no letters.
They were between $140-$150 just a few weeks ago (Cummins NW)... Must be the "supply and demand" theory at its best... ;)
Yeah I heard that - I was surprized myself, as I previously heard $148. 00. Probably should pick one up as a spare anyway going on X-Country trip again this summer - got 92,500 miles and dealer just put a new one on last week. Just hope if it goes bad it dosent take me the 2. 5 hours it did for the dealer's Tech to install one. :-laf
I just picked up a lift pump today #3990105 $ 146. 00. From LA Freightliner in Fontana, Calif. Phone # 909-510-4000. Open 24 Hrs. ;)
