Had been following the recent thread concerning D/Cs STAR Hotline and lift pump pressures. D/C said minimum fuel pressure at any throttle position should be 8psi or higher. This is what I had:
Idle: 9-10psi
Cruise at 65mph: 6-8psi
WOT: would go down to 1-2psi
Took a copy of the thread to Tacoma Dodge and they checked it out. Their diagnostic said fuel pressure was 11psi idle & 7psi at high idle (may have been measuring pre filter). They also did a "fuel restriction test" and said it was 2. 6HG at high idle (this may be across the filter). They said the lift pump was bad and replaced it.
Now I'm seeing:
Idle: 15+psi (gauge only goes to 15)
Cruise at 65mph: 12psi
WOT: 10-11psi
What to you get for you $35 annual subscription to TDR????? You get valuable info!!!!!!!!!!
Idle: 9-10psi
Now I'm seeing:
WOT: 10-11psi
