Carter
The Carter 4601hp fuel transfer pump is a 100GPH @ freeflow and close to 80GPH at 15psi. Someone on here has a post for what the volume should be for the 25sec bump test so you can check it BEFORE you take it to the dealer and they check it. This way if you are still under warranty you will be sure that it is bad so you don't get charged a diagnostic fee.
