HeavyHauler said:Well... I dunno, but replacing a lift pump based only on a post-filter test isn't a good idea in my book (or to Dodge apparently). If you really want to get technical, you should measure both pre and post filter and then measure the pressure drop. The specs are in the service manual.
Oh, and his VP was replaced back in November, and that's plenty of time for a fuel filter to become restricted.![]()
nps said:Dodge does check the fuel filter - only AFTER the post-filter lift pump test fails. If the LP is good post-filter then the filter is good by default - right?
Nobody ever said to change a LP on a bad reading. So there is no argument, other than your statement that apparently Dodge does change LPs solely on a low post-filter reading. They don't.HeavyHauler said:Well I think that's pretty obvious - my point comes from when a lift pump is replaced solely because of a low post-filter reading. I don't see what the argument is.
Accuracy isn't the objective of the test. Good enough volume is. If the LP can do 45 oz with the filter installed, that's good enough. If the LP can't, then Dodge says to check inlet pressure with a gauge - something the thread originator doesn't have or we wouldn't be debating this anyway.HeavyHauler said:There's no way that pulling the line post filter and then measuring the volume can be a 100% accurate test.
If this is true then "most dealers" were doing the test incorrectly. The ISB transfer pump test procedures in the Factory Service Manuals, used prior to TSB 14-002-03, never checked fuel volume. Also, checks of fuel pressure were to be done at both the inlet and outlet of the fuel filter (Schrader valves at inlet of fuel filter & VP44),HeavyHauler said:I'd pull the line between the lift pump and the fuel filter instead of the fuel filter and VP44. ... . This used to be how most dealers checked the lift pump...
Thomas said:If this is true then "most dealers" were doing the test incorrectly. The ISB transfer pump test procedures in the Factory Service Manuals, used prior to TSB 14-002-03, never checked fuel volume. Also, checks of fuel pressure were to be done at both the inlet and outlet of the fuel filter (Schrader valves at inlet of fuel filter & VP44),
nps said:So what the thread starter needs to do is check volume post-filter. If it is bad, then change the filter and see if it improves. If still bad, then it's LP time.
Guess not. But he did ask for a test procedure WITHOUT a gauge.HeavyHauler said:... doesn't make sense to me.
