While driving with the test gauge post filter at W. O. T. saw 5psi. Went to dealer with this info. They tested it and said it's within specs. The way they tested it was post filter and saw 14psi at idle and 10psi W. O. T. but , parked not driving it. Dealer also said something about a vacuum forming at W. O. T. while driving and the pump very likely would drop to 5psi. Two other dealers said the same thing.
I called Cummins. They say the way to test it is pre-filter, cranking no less than 7psi, and no less than 10psi at idle.
Cummins does not have any specs as to what the psi should be at W. O. T. either driving it or parked.
So my questions are, who's right? Who came up with the idea that 5psi while driving at W. O. T. meant a bad lift pump. Was this Star?
