I just took my truck into the dealer because it was slow to accelerate or bogging down when cold- it clears up after 15 to 20 minutes of driving. I didnt think it was the lift pump because I had a solid 12-14 psi on my gauge- never goes below 8psi at WOT. The service rep said that i had a hard code lock for the LP & possible APPS. He said that he then did a fuel flow test & the fuel flow test failed at 30 ounces in 30 seconds & normal is 52-56 ounces/30 seconds. They wanted to change the LP & APPS to start. I have almost 80k miles on it & the service rep says that I got a lot of service out of this LP as it is. He says that they see this all the time & change a lot of LP's.
I decided to install the FASS system instead & have it on order. Just to confirm my fuel pressure gauge was reading OK, I bought a mechanical direct test gauge & confirmed that my guage was correct. Has anyone heard of this method of testing? The service rep said that the mechanic said that this is how they test the LP & doesnt care what the fuel pressure is. He said that if I wanted my fuel pressure tested, he would charge me another half hour labor. This confuses me as all the reading on the forum talks about fuel press & not flow.
Does anyone know how to do this fuel flow test? I dont have a factory service manual. I plan to do this test before & after installing the FASS system.
