kboettcher
Well, I didn't get a new lift pump but, I did buy a Carter P4600HP pusher at the local auto parts store for $153CAN. Installed it exactly the same way Steve L. did his, turned out really good. Thanks for the info and the pictures Steve. Then I took it for a run.
My pressures before the install were as follows
starter bump- 10. 5 psi
at idle- 10 psi
cruising at 50 mph- 8. 5 psi
WOT- 4. 5 psi
New pressures with the pusher are
starter bump- 17 psi
at idle- 17 psi
cruising at 50 mph- 15 psi
WOT- 11 psi
I'm pretty happy with those pressures, do they look ok to everyone else? I don't have a permanent fuel press. gauge yet but I will keep an eye on the pressure with my hose and gauge setup every couple of weeks till I get one installed
at idle- 10 psi
WOT- 4. 5 psi
at idle- 17 psi
WOT- 11 psi
