DKasper said:
Could there be some restriction between the tank and the lift pump that is stressing the capabilities of the lift pump? I can't imagine 5 pumps being bad/wearing out in that period of time . . .
Funny you should ask. I've been suspecting fuel supply restriction for some time now on my 91. 5. I've been getting intermittent blue gray smoke as well as poorer mileage, and an idle speed that varies +/- 200 rpm depending on vehicle inclination (truck pointing uphill or down). Replaced fuel filter twice (cut them open both times-clean) and the lift pump. Then, as per the shop manual, I tested for fuel restriction by installing a vaccuum gauge before the lift pump. The manual states : " maximum allowable restriction is 3. 75 inches hg. Do Not operate engine if restriction is above this amount, or damage to the injection pump may occur". Well, whaddya know, climbing a hill under load my gauge showed app. 10 inches hg! And when backing downhill and applying the brakes, it would read 8, while my tach fell 200 rpm! And when heading downhill and applying brakes, tach would gain 200 rpm and restriction was at 0-1! So I'm saying to myself, self, it's time to yank that bed off, get in that tank, and see what the heck is going on. So, I fire up my trusty 843 bobcat, (diesel, of course) and in about 30 minutes I've got the bed unbolted and off. Got the fuel pickup assembly out, and sure enough, the inner filter screen was pretty much plugged up with glomation, oh yah and there was also an old fuel additive cap-foil floating around in there too ! Has anybody ever taken out their fuel pickup assembly and really LOOKED at it? What a convoluted mess of a design. No sir, I don't like it. It has a plastic reservoir cylinder~4" in diameter that is screwed to 2 slotted steel brackets to allow for adjustment, the screws had loosened up and it was sliding up and down around an inch and a half. It has an outer screen at the bottom with a float and a foot valve. It appears that under normal operation, the float is up, allowing fuel to flow from the outer screen, up through the foot valve and into the pickup tube. But when the tank is almost empty, the float falls to the bottom of the screen cage closing the foot valve and causing the fuel to now be drawn from the smaller inner fuel screen within the plastic cylinder/reservoir. But guess what? The float gets saturated in time, and sinks, stays sunk, causing the fuel to always be drawn through the smaller, more prone to clogging, inner screen. And by the way, that hard plastic, spiral, fuel pickup tube? It's probably less than 1/4" inside diameter at its smallest point. The guys have been talking a bit lately about fuel supply restriction and electric pumps and what not. I'm thinking of adding an electric pump too. But take the time and check your fuel pickup assembly, you may be amazed at what you find. GOOD LUCK! K2
