2nd Gen Non-Engine/Transmission lift pump
I would like to change my lift pump on my 2002 cummins to a frame mounted pump. When I remove the stock lift pump, does anyone make an adapter to put in its place. I would like to leave all stock fuel lines and filter but just remove the pift pump. Thaw way fuel could just go thru the adapter where the stock pump use to be.
No need for an adapter in its place. I moved mine and left the factory bracket on the side of the engine where the pump was attached. If you get a l. p relocation kit it has everything you need to mount the l. p on the frame including a new mounting bracket. The kits are the best way to go, you get everything you need to do the relocation. You will need to have a way to cut the factory metal fuel line where you mount the pump in order to plumb everything in. You will have a rubber fuel line from the pump to the filter assembly afterward.
VULCAN PERFORMANCE - TRANSFER PUMP RELOCATION KIT-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
lift pump relo
I used the relocation kit from genos ,and a drrp,fast on my 2002 and also 2001 ,works great. hope this helps;)
