Lift Pump ?
TSB authorization error
BHAF Rivisted with Suggestions
I know this has been beaten to death, but where is the best place to get a stock type lift pump?And what can i expect to pay? I noticed yesterday that i could not hear mine when i first started the truck so today i went out and cracked open one of the fittings on the filter housing, bumped the starter, and no pump. I tried an old starter trick of tapping the pump with a hammer and it is working again for now. :(
Rattler, if you want to stay stock go to Cummins and get their latest and greatest #3990105 for a cost of $142. 66
It will bolt right up, I dont know if you need the wiring harness or not, look at your stocker and see how the wiring is , if it clips right in to the bottom than you will not need the harness, hope this helps,... ... ... ... ... ... Kevin
You Guys are Lucky
Our local Cummins shops are very proud of the new part number. They want around $165. 00 in the Baltimore/Harrisburg/Philly area.
Dave
