Voltage at the lift pump?
Juicedcummins may be on to something with his comment about the factory wiring being too light.
Is it possible that our lift pump problems are not caused by a bad lift pump design, nor by installing it so far from the fuel tank, but rather by low voltage?
If the wiring is too light for the load, then the lift pump will be running at less than 12 volts. I'm not an electrician, but I do know that electric motors will fail if they are not supplied with sufficient voltage.
Has anyone measured the voltage AT THE PUMP when the lift pump is running? If so, what voltage did you read?
I have a meter and may be able to get a reading from the connection at my relay (that controls my booster pump). If I take the measurements, I'll post the data.
Loren
