WELL, as far as I'm concerned, the issue of "air in fuel", and promotion of "systems" designed to provide significant VP-44 or engine function improvement due to "air removal", is another of those urban legends and old wives tales. Sure, there is undoubtedly SOME air/vapor that naturally gets entrapped in the fuel flow from LP action and other system peculiarities - but as has been pointed out, the VP-44 design already covers that with an internal air separation design that then feeds any air back to the tank in the fuel return line.
Is it likely that MORE air might be "generated" in the fuel system - perhaps by overkill pumps that provide FAR more PSI and flow than the VP-44 wants, needs or can use? Probably - but in those cases, significant efforts to then REMOVE that air is pretty much an admission of a system that is poorly designed, and NEEDS the added "crutch" to remove the air it ITSELF has created in the fuel flow!
Hi Gary,
Let me answer that question for you! (REMEMBER, YOU ASKED)
The quest to separate air, specifically entrained air from diesel fuel and also vapor has been attempted unsuccessfully, by many, since 1892. If you study these earlier attempts by the patents that are registered with the U. S. patent office and also the PTO's of other countrys, you will see a maze of these devices. The Fuel Preporator, which was developed starting in 1990, is currently the only true fuel air separator on the market. There are bubble eliminators out there which, to some extent can separate fuel and air. I will explain that.
First, damage to injection system components caused by air in fuel is a known issue and is fully addressed in all diesel engine manufacturer's service manual trouble shooting guides.
Second, the affect of air on the performance of the diesel engine that utilizes a barrel/plunger assembly to inject fuel is well understood by the industry. The compressibility of air and fuel vapor delaying the pressure build up in a barrel/plunger type injection system and causing retarded injection timing is what has led to the development of the common rail. In the common rail, the spray of fuel into the cylinder is caused by the release of fuel from a high pressure reservior, the common rail, by a computer (ecm) controlled valve.
Removal of air from the fuel!
The removal of air from the fuel by the Fuel Preporator system, developed starting in 1990 and of which the AirDog is the smallest model, happens as follows:
The air separation details of the following narrative can be found in the Fuel Preporator patent 5,746,184. This patent has a priority date of 1992.
Fuel with entrained air flows from the tank, through the lines, through the wire screen water separator and into the pump of the AirDog. Now we have positive pressure under our control. The fuel flow coming from the tank is drive by atmospheric pressure trying to equalize or satisfy the demand of the pump. From the pump the fuel flows under pressure into the filter, the filter fills. Fuel passes through the filter leaving the separated air bubbles behind. As I pointed out in my 1992 patent 5,355,860 Cummins explained this in their Service Topic 5-135. Air is separated from the fuel by the resistance of the passage of air through the wetted filter element. This is why filters on the vacuum side of a pump are most always low or partially filled.
So, now the air is separated, it can float to the top of the dirty side of the filter (this is important, remember it). The Fuel Preporator/AirDog has a bleed hole at the top of the filter (dirty side) to discharge the air into the return to tank line. Note, the fuel (without air) passes through the filter element. Inside the filter element, extending down from inside the nipple that holds the spin-on filter in place, is a pickup tube (we call it a depth extension tube). This is the passageway that takes fuel from the bottom of the filter element for the engine. It is extends to the bottom to take fuel that is free of air bubbles that may randomly pass through the filter and also air that was in the filter from filter changes.
The space between the nipple and the depth extension tube is the port for the fuel the engine doesn't need to flow back to the tank. Again, any air in the filter from filter changes or that has randomly passed through the filter may return to the tank with the fuel. Located in the return passageway is a regulator that maintains internal pressure. This is what sets the out to engine pressure. The primary air exit port, mentioned earlier as the tiny air bleed hole on the dirty side of the filter, enters the fuel return passageway after the regulator. This is important, as the regulator closes as fuel demand from the engine or the filter restricting the fuel flow as it gets dirty, the separated air can still get out.
The Fuel Preporator also has flow dividers, patent no. 6,729,310. These separate the dirty side of the filter into an inlet side and an outlet side. With these features, the little AirDog can separate air at flows in excess of 150 gph. Without the flow dividers, it would take a 5" OD filter to do the same. Without the primary gas exit port and the flow dividers, our tests show that the system will stop separating air from the fuel as the regulator closes and or as the flow to the engine exceeds 30 to 40 gph.
The FASS has only the depth extension tube extending up to a passage way that goes out to the engine and the fuel return passage with the regulator feature for air separation. The air is separated by the filter in the Fass . All of the separated air is trapped on the dirty side of the filter where it stays until the equilibrium point is reached. It is then forced through through the filter where it emerges as larger bubbles, no as the tiny bubbles of entrained air. If the regulator is open and flow velocities are low enough for the bubbles to float, it can rise up and return to the tank. If the regulator is closed, the passageway to the engine is the only exit from the system. Additionally, if the velocity of the fuel through the system is to fast for the air to float up out, the air will again go with the fuel to where ever the fuel goes.
I hope this will help you to understand how these fuel / air separation systems work!
Please excuse the typo's!
Charlie
