When I first joined TDR I asked a question about an exhaust tick behind the cab, that my truck has had since day-one. I still have it and am positive its the elbow in the fuel line at the top of the tank. No big deal, nothing that louder exhaust won't fix.
I now have a tick in the general vicinity of the lifter pump. You don't hear it when its idling, or when your @ 2000 rpms going down the highway. But when you let off and let the engine slow the truck down, and the rpms hit between 1500 and 1700, you hear a tick, tick, tick. Sounds almost like a lifter tick in a gasser. I haven't checked the fuel pressure before the injector pump yet, but I'm wondering if it is the lift pump at all. While in the cab driving the tick sounds like its forward and below my left foot.
I've never had one go out on any of the dodge diesels I've driven. Has anyone heard this noise or had a simular problem with the lift pump? If so how much does a lift pump go for?
If it is the lift pump spring and arm making the noise at a certain rpm, then I'm rolling the idea around of using an electric fuel pump as some other TDR memebers have talked about.
Any ideas?
Kurt
97 2500 SLT Reg cab 4WD, Emerald Green and Driftwood, 3. 54 gears, 2. 5" Tuff Country Steel Coil Spacers, 295/75/16 AT BFG'S on Alcoa's, Trailmaster SSV shocks & SSV steering stabilizer, Holcomb Air, Amsoiled, stock--#10 TST plate and AFC Spring Kit thats waiting on a new clutch
K. Kinion
Any ideas?
Kurt
K. Kinion
