I recently changed my rear dif. oil to Amsoil 75/90, and it immediately started making noise going around corners. I then added 8 oz. of friction modifier, did some figure 8s and all was good.
A few days later I had to back-up around my u-shaped driveway, and I could hear and feel limited slip (LS) chattering. I thought it would probably go away with more driving, but after 3K miles, it's still the same. But only in reverse.
Have any of you guys had this problem?
Should I just add more modifier? I've heard too much will make the LS less effective, true?
Do I need to do figure 8s in reverse, before I try adding more modifier? It's just noisy enough I'm concerned it might hurt something by doing that. Will it?
TIA for any input on this, Ray
98 12V, dually.
98 12V, dually.
