The only mistake I made when I ordered my truck was not ordering a LSD. I figured there would be lockers available soon enough. I was wrong, here I am 2 years later with zilch. .
CRumsey said:I'm glad that there are so many here who are happy with this LSD; but my experience has been a little different. This past winter if all I would've had was the LSD I would have been stuck on several different occasions. I was really glad I had purchased the 4 X 4 because it was what got the truck going when the LSD did not function. As previously mentioned this is a torque differentiating differential. Meaning both sides need to be on something that will create traction of some sort to turn both wheels. My experience was, and this is a fact, with the left side sitting on dry salted pavement and the right side setting on ice or snow; the right side on the ice would spin and spin while the side on the pavement sat there and took a coffee break. I had to switch into 4 wheel drive to move the truck and it happened more than once. My feelings are that this is a severe limitation in the capability of this differential. It was such a problem that I took it in and complained that the LSD was not functioning; the dealership said it was functioning as designed.
XJSuperman said:CRumsey... I would have expected this and any 'anti-spin' or 'limited slip' differential to behave just as yours did on the ice. Only a 'locking differential' or spool would have made both wheels pull. When enough pressure is applied to one wheel of an LSD or anti-spin diff... it will act as an open diff... . OR if one wheel has significantly LESS traction than the other which is what your case is/was... it will act exactly as it did. Basically if you had one rear wheel off the groudn and one on the ground... the one in the air would spin. With any lsd or antispiin... yes... it is significantly better than an open diff... BUT you still need somewhat ideal conditions. Hence the name "anti-spin" and not "locking differential"... I apologize for sounding like a smart-alec... if I do I'm not meaning to do so.
NSperduto said:Riddle me this one, then. I have a 98 Dakota that was equipped with antispin or LSD or whatever you want to call it. I can put one wheel on the ice and the other on the pavement and they both spin at the same time and away I go. I get absolutley zero spin out of the wheel on the ice.
I pull up to this same exact spot with the ram and I sit there stuck in 2wd.
I know this for a fact because I still own both trucks and I go to one specific corner all winter that always has ice and snow on the side of it at the stop sign where I need to stop, check traffic on the highway and pull out. I step on the ram pedal and away she spins. I step on the dakota pedal and I zip out onto the highway.
Maybe you guys who love the LSD in the RAM never drove a truck with a real posi unit. Or suregrip as the older mopars used to call it.
Nick
XJSuperman said:but after enough mileage you'll eventually wear out the clutches and have an open diff.
JHardwick said:whew, talk about the long way around the mulberry bush!
XJSuperman said:#1) It's gear driven... there are no parts to wear out ever. So unless you actually break it it will last indefinitely.
JPereira said:I had bought my 4. 5 Ram last spring. I did order the truck with the limited slip. I recently changed the fluids in both front and rear and was surprised to see the front does not have the same LSD like the rear does? The is my first 4x4 so I did not know if this is normal? Does that mean only 1 tire is actually pulling up front when in 4x4? Is the front what they call a standard Open Diff?
Jeff
rbattelle said:This is completely normal. There are very few vehicles out there that come from the factory with a limited slip front end. I think Jeep Grand Cherokee's with the Quadra-Drive do, and I think the new Dodge Power wagon does, and probably some high-end stuff like Land Rover might, but they are the exceptions. The front, then, is a normal "open" type differential.
With luck, one of the aftermarket lockers will become available for our axles.
-Ryan![]()
E7mack96 said:my $. 02,
The limited slip in my '03 ram works great. maybe too good. It breaks one set loose on almost all turns. in the rain, it can get scary in a turn.
My rear tires are almost bald at 40,000 miles, but the fronts look great.
I attribute this to the rear limited slip spinning one set in the turns.
