Limited slip problems
Bad News.
~Rotella CHEAP? At B.J's~
Mine will be a lock rite. I ordered a brochure from the company. www.powertrax.com
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
to restack the clutchs just pull the axles unbolt the carrier caps,pry carrier out,on bench unbolt 8 bolts holding case together. take clutchs out thay should be stacked driven then drive 3 times,then 3 drivens together 3 drives. to make it more agressive alternate driven, drive,throughout. (drives are the clutchs with tabs,driven are splined inside.
01,white 2500 q-cab,4x4,auto4. 5"sky jacker lift,315/85/16(36")tires
While we are on the topic. Should our limited slips be able to roll off a jack that has one side a couple of inches off the ground?
My truck just stays there with that tire spinning in the air!
2001 3500 slt+ sport HO ETH 6spd every option available Black with agate leather
3:54,Class 5 hitch,BD E-brake, BD two Low Kit, K&N filter
I was backing into my driveway, and sometimes
ease over a small curb at my driveway apron
to cut the corner better. Especially if the car in my driveway is not over far enough. I am also concerned about the limited slip possibly not working, as the front tire came up against the small curb, I just gave it a little more and the right rear spun on dirt but the left rear did not, it was on concrete. Isnt limited slip supposed to work in reverse also?
