Well today I decided to rotate my tires on my 03 DRW 3500, what a job that was. While i had the rear end in the air i decided to verify that my truck was a posi. Big surprize, when I turned one side of the duals the other side turned the opposite way! So I started it up ,put it in gear and figured I would try and stop one side from turning and that would prove my suspicion that I had a open rear and not posi, sure enough I was able to stop the one side with my foot! I double checked the info sheet in my glove box and sure enough it came with a limited slip rear! Does anyone know what type of posi the American Axle uses? Am I right in assuming that I have a non posi rear?
Also checked my ball joints and they are bad . 026 verticle play on the right side and . 023 on the left.
