Just my $0. 015 but I've had good luck with the stock LS if set up properly. Yes, it's not hard to restack the clutch plates but unless you are sled pulling I don't think that it's necessary. Chrsyler puts an excess of limited slip additive in the factory fill to avoid warrenty complaints on noise. Completely drain the Dana while hot, jacking up each axle a bit to drain the tubes. Refill with your favorite lube, preferbly a brand that recommends additional limited slip additive. Drive the truck doing the recommended figure "8's" etc, then drive a couple more days normally. If the limited slip clutches are tight you should get some popping and noise while turning in parking lots and such. If the noise/operation it tolerable you are done. If not use only the Mopar additive and add two ounces at a time and drive a few days in between. Remember that if you want a strong limited slip (Detroit Locker are noisey!) you can't have it so quiet that is slips all the time. Last thing remember that our Cummins have an awesome amount of torque that is transfered to the differential. When traction varies greatly (side to side) it is wise to slightly load the limited slip and go easy with the power. Larry
