No hands on experience with this one but here is what I found. I did not see a difference between the VIN 6 and VIN 7 sheets or location.
SYMPTOM
P0121-ACCELERATOR PEDAL POSITION SENSOR VOLTS DO NOT AGREE W/IDLE VALID SIGNAL
WHEN MONITORED
During idle which is less than 15% of full throttle range for approximately 1.0 second or during not at idle and vehicle speed is greater than 10 MPH for approximately 1.0 second.
SET CONDITION
IVS indicates idle while APPS signal voltage indicates not a idle condition or WS indicates not at idle while APPS signal voltage indicates idle condition.
POSSIBLE CAUSES
- APPS
- APPS wire harness circuit open
- APPS wire harness short to voltage (IVS # 2)
- APPS wire harness short to voltage w/engine ON
- APPS wire harness short to voltage with key ON
- ECM
