Line-X probably didn't go out of business due to the local cold snaps as this stuff has been tested far below -30 degrees. What happened is a couple of years ago when these liners first became popular every shop decided to do it and flooded the market. As such, individual franchises decided it wasn't worth the investment and after a few years decided to get out of it. I've seen franchises from Rhino, Line-X, and every other knockoff go out of business. It has little to do with the mother companies. In fact, very few individual franchises offer all the options that the mother company offers. For example, many only offer the product in specific limited colors as it is too expensive to keep all the colors on hand for the one customer who decides they want a lime green with just a hint of aqua marine for their bedliner.
In all actuality there are only three main types of professionally sprayed liners. The super soft ones that work really well for keeping a load from sliding and general protection and cushioning like Rhino. The semi-rigid ones like Line-X that are much more durable to scraping etc. And the cheap ones that are sprayed in so hard that they chip at the slightest whim.
The thing to keep in mind is that most of the companies are spraying the same stuff no matter what the Name Brand. Just look at them and figure out whether it is a Rhino knockoff, a Line-X knockoff, or one you can do without. I believe Perma-Tech is blowing a product very similar to Line-X and if you trust the installer go for it. Remember it is the installer that will either do a great or a poor job, the products they are spraying are pretty much proven no matter what brand. Most use some gimic and many will try to pursuade you that one is much better than another.
When I went and installed mine, I was lucky in that I only had two choices in the Quad Cities. Line-X and an off brand that when asked to compare their product to the Line-X they told me they thought the Line-X was what they considered the best durable liner on the market and their own product wasn't nearly as durable but a couple of bucks cheaper. I got to choose the color as long as it was black so that is what I got. My Father on the other hand has a Perma-Tech installed in his truck in the gray color. Not as hot as mine in the summer but stains worse due to the color. He also has a few cracks due to the cold temperature when they installed it(installed in the winter and metal was too cold and they were new) but they said they would repair it anytime and it is only on the tailgate and doesn't bother my dad. Other than that they are nearly identical.
